sfav8r
- San Francisco Bay Area
We came across a situation yesterday where a client store a battery near the conduit that feeds the service panel. Apparently this did not make the 2" galv. conduit happy. it is corroded from the point at which it penetrates the concrete up about 2". it is completely eaten through just on the back side which a sizable hole. This si the conduit that runs to the utility vault. I assume it is not Galv. all the way to the vault, but rather transitions to PVC under the ground but I haven't confirmed that. My question is, would there be a problem just sealing the hole by flashing with aluminum tape and then pouring concrete around the conduit? The location of the conduit will make it very difficult to cut the concrete and dig down, cut the conduit and replace the bad section.
Thanks
Thanks
