Repairing entire inside of service panel question
ldhope
New User
california
retired
I have an old zinsco panel that should be replaced because the busbar has a breaker welded to it due to arching except it will cost more than I can afford. Let me explain the circumstances. It has the wire from the street running underground. The panel is set in cement and there is a gas meter about 3 feet away. Current code requires the meter be moved because of the gas meter. If I put in a new panel I then have to run the line back to the homes enterior panel (it's a mobile home) which means cutting through the concrete or running a line overhead back to the mobile and even then I'd still have issues connecting back up to the panel. So here is my question. Is it possible to repair the old panel. I'd like to remove the breakers, busbar and install something that fits and is safe (not zinsco parts) if that is possible. I got a rough estimate of 10-15K to put in a new panel which is way more than I can afford.. Any ideas or suggestions?
I am closing this thread, in accordance with the Forum’s rules.
This site is designed for:
Contractors
Electricians
Engineers
Inspectors
Instructors
Other electrically related individuals
This NEC Forum is for those in the electrical and related industries.
Forum rules prohibit us from assisting a person to perform or assist others to do electrical work who are not qualified. The reason is that the forum’s owner does not want a person to get an answer to the question they asked, but not get answers to the other questions they should have asked and were unaware they needed to ask. Mike Holt Enterprises and the Moderators of this Forum do not wish to place you and your family in danger, by allowing others to give you too little information to ensure that the installation is safe.
