Forum,
Long story short, we had a 60 hp motor that was started 21 times in about 13 minutes. The system was set up so that the motor started/stopped based on a level indication, and that level hovered around the start/stop point. What I'm confused about is that the HMCP circuit breaker eventually tripped. I thought HMCP's only operated on magnetic principles?
(it was eventually restarted later, we learned of these excessive starts after the fact, so there wasn't a fault, thankfully). Could you guys provide some insight into this? Much appreciated.
