In a heartbeat:thumbsup:Id replace the guts of the panel.
So by code I can or can't do it ?
从我的 iPhone 发送,使用 Tapatalk
If you file it down, you no longer have a listed component. If you want it to be listed, you'll need to submit it to a NRTL and pay far more than it would cost to just replace the panel.
Maybe I should clarify. No to the file it down. Yes, to replacing the panel innards and breaker.Can not.
I got a Siemens main breaker was burned/ overheat . the metal parts of the breaker and
Bar both are carbonized, it cause some sparkles arcs . Could I just file the bar and replace a new breaker? Is it the contact good enough?
Regardless if you clean it up, or replace the bar/breaker -
did you cure the overload or whatever was the original bad thing?
i don't think it is overload. It just a small dwelling unit, the reason for that just the breaker didn't contact to bar not good
