Designer69
I need to remove an existing Auto Transfer Switch that is internally mounted in an MCC cubicle and replace it with a new larger externally mounted ATS.
My question is, what is the best way to make the connection of the new external ATS to the same MCC? I was thinking use a smaller bucket in the MCC with a circuit breaker and tie in there. Unless it's better to just use an empty bucket with terminal lugs only and connect there?
I'm not too experienced with this so I'd appreciate your help. Thanks
