Mikoz
New User
- United States
Hi. I have recently installed a few car accessories, including new replacement LED lights. However, I noticed a problem with the brake lights when I put it on the road. I discovered the cruise has been affected and now it didn't work. Do you think the problem started with the replacement led bulbs? I've read that the original housing is not designed to dissipate heat that's why the LEDs work harder. Can I still save the light assembly or should I just replace the whole part?
