Cow
- Eastern Oregon
- Electrician
These old Unicorn panels are pretty common around our area.
Same old thing with this one, the main breaker burned up and took the buss down with it. Managed to install another used main breaker with some deox for a temp repair until the can is replaced here shortly. The problem is when we replace these, the existing POCO feed comes in on the right but the new Siemens meter main combos we typically use have the POCO feed on the left. We end up digging those 2" pvc sleeves out and swapping the direct burial wires across each other to make it work. Which definitely doesn't help with the wire length situation. Does anyone know of a better can or brand to use that may work a little better? Does every brand have the meter on the leftside nowadays? Thanks.
Forgot to add, ideally the meter main typically needs to have at least a few spaces for some branch breakers as well. This particular one has just one 2 pole in there to feed the pumphouse.
