smileyrules
- toronto
Hello Everybody,
I'm working to supply power to: 1. 45kVA transformer and 2. 15kVA power pack.
the existing splitter is supplied with power from a 600VAC MCC (50Amp breaker); using a 3C #2AWG TECK cable.
What is the cable size I can use to connect to both loads? and,
What is the acceptable rating for the Disconnect Switch that I can install inbetween the splitter and each load?
So far, I'm thinking of using:
for the 45kVA Transformer: 3C #2AWG cable with 60Amp switch.
for the 15kVA Transformer: 3C #12AWG cable with 200Amp switch. is this acceptable?
Any response is appreciated.
Thank you,
Bassam M.
Thank you,
Bassam M.
