L
Lxnxjxhx
Guest
When you encountered some electrical problem that "couldn't possibly be happening", something that defied all logic and yet it really was happening,
after it was solved what did it eventually turn out to be?
For me the cause of these situations was my assuming something that wasn't true, and it turns out to be very difficult to get at all the assumptions we make in everyday life.
E.g., a bad solder joint that gave different voltage readings depending on how much pressure you put on the test probe.
