- Illinois
- retired electrician
Last night a traffic accident took down a power pole and 2 of the 3 conductors of the service drop. One ungrounded conductor of the drop remained connected to the utility. The riser was damaged and the still connected ungrounded conductor was shorted to the grounded conductor. The water piping was bonded, but was served by a nonmetallic service. Current flowed on the water pipe to the gas water heater, and then on the flex gas line. I am not sure of the complete path on the gas line, but I think there was a path via the metal gas piping, the gas meters and the grounded conductor at the other unit of the duplex. The current either burnt a hole in the flex line or burnt it completely off and the gas was ignited making a torch in the utility closet. The flex line was completely seperated when I saw it, but it is possible that the current only made a hole and the burning gas did the rest. It is also possible that the current did the complete job. The home owner called the fire department and then put out the gas fire with a dry chem extinguisher. The FD shut off the outside gas valve and stood by until the power company arrived to cut the hot wire.
Don
Don
