MiltSanders
- USA
- Engineer
First, I am new to NFPA70E and the NEC. I have purchased these materials and trying to learn to navigate and find things is yet a work in progress. I wanted to reach out to you all and ask for guidance in how and or where to look.
Here is what I have: I have an Indoor MCC Room that is 25 feet wide and 75 feet long. The left side has PLC cabinets with doors and PLC hardware installed. All voltage on the left side is 120 VAC or less. On the right side of the MCC room, there are Eaton breaker cans with the breaker disconnect handles sticking out the front (HDK 65K). The right side for the most part is 480 VAC with only access to the components is from the front. There are ARC Flash stickers ranging from 0.5 cal/cm^2 @18" to one that reads 7.3 cal/cm^2@18" with an ARC flash of boundary of 61 inches. There are entry and exit doors at both ends of the MCC. Also, there are “no” live conductors exposed unless bolted covers are removed on the right side and or a PLC cabinet doors are opened and safety covers ignored.
My question is, if all the covers and doors are in place and closed, how can I figure out what PPE is required for passing through this room and doing no work? I have looked through Table 110.26, Table 110.26(A)(1), Table 110.27(C), Table 110.31(B) of the NEC and all I keep seeing is “exposed live parts”. If there are no exposed live parts and the doors are closed and the breaker covers installed and bolted, what PPE is required for my worst situation (7.3 cal/cm^2@18" with an ARC flash of boundary of 61 inches) if I can stay about ten feet away from the ARC Flash Boundary? If someone could help me locate the area in which to locate this information would be very helpful.
Regards,
Regards,
