The NEC is pretty clear in its definition of a bathroom as well as the electrical requirements for such rooms but I'm wondering if these requirements/definitions are explicit enough. What provoked this is the following scenario (or ones like it):
New construction with an upstairs bath basically consisting of three rooms. From the hallway, you would enter the 'main' room which would contain two vanities/basins and a fair amount of walking space (probably 8'x8') as well as a linen closet. On the left side of this area there is a doorway leading to the tub/shower area which is also about 8'x8' and contains nothing but the built in tub/shower, and will probably have a bench of some sort to be a changing room. On the opposite side of the 'main' room there is yet another doorway which would lead to the toilet area. Much smaller and contains only the toilet and a small closet. In the case of this example, let's say that the homeowner wants 125V receptacle outlets to be installed in each of these 'rooms'.
What I'm wondering is whether or not these three rooms would meet the definition of a bathroom per the NEC (an area including a basin . . .) and thus have to meet the electrical requirements for bathrooms. Personally, I think it's obvious and anyone worth their salt, IMHO, would treat all three of the 'rooms' as a bathroom and wire them accordingly but the devil's advocate in me wants to say "what is an area?". Strictly speaking, could each of these rooms be considered to be in the same area even if they are separated by walls and doors?
On a related topic, I believe that a room that contains only a tub/shower should at least require GFCI protection for receptacles within some distance (maybe 6ft?) of the tub. I've heard of proposals to expand the GFCI requirements for sinks but have there been any for tubs?
Maybe I worry too much, but I would like to hear some other opinions on this.
Thanks for reading,
Jim
Thanks for reading,
Jim
