sgeers
- Vernon, NJ
Got a call to come out and look at this residential service upgrade. Usually every one i have done thus far has been fairly cut and dry, but this has me asking myself alot of questions.
The panel is currently an old 60 amp murray, and is located directly inside the home behind the meter, which happens to be in a small closet. In this closet is the water meter (4 feet from panel) and a large drain pipe (directly under the panel). The HO wants to eventually build a wall in this closet and make part of it a shower for the bathroom which is located about 6' away from the panel. This would make the shower about 3-4 feet from the panel.
He would like a 200 amp service installed either next to the old service, or all the way behind the house in the garage. This would require running the service wire through the basement beams and into the garage, which is about a 60-70 foot run total.
I guess what I'm asking is which seems like a better plan of attack. Im supposed to start this project a week from today. Ideally, I would prefer to keep the panel located close to where it sits now to avoid the extra expense of extending wires and running the service wire through the home. I'm having a little trouble finding things in the codebook pertaining to such a situation
