Re: Resi well Voltage drop
peter d,
I did read your posts and 10 AWG minimum with an #8 feed is correct. The static head you mention is another factor if the impeller sections do not match the GPM output requirements. With that said, a 3/4 horse may not be adequate. I think the main issue is getting the pump up or down the well. (usually 6" casing)
Sometimes the driller needs to case beyond the required minimum depths because of geological fissure anomalies. I've been on jobs where casing to 400 ft was necessary due to cave-ins.
electricmanscott, I'll re-phrase my question with additional info you may be interested in.
What is the driller's Gallon per Minute final report and what is the well output design intention? With that data a better answer would be forthcoming. Also note, rural insurance firms usually require a minimum output in case of long fire response time to the site. In some cases I have installed storage tanks to compensate for low yield wells. Yes, another high output pump is generally needed.
rbj, Seattle
[ December 23, 2004, 07:45 AM: Message edited by: gndrod ]
