Battlebornelectrician
- Reno
- Electrical contractor
I have a residential 400A MSP that is needing Generator backup. Inside there are 2-200A MCB. Both are fed from the bussing straight off the meter and load out to 2 separate subpanels inside the home via sub feed cables inside the MSP. I would wire in 2- 200A ATS, one for each feed. Standard. HOWEVER, I have been getting really tripped up on how many neutrals are needed going back and forth between the MSP and ATS. Lets take just one of the 200A feeds and ATS for example. If I run one of those 240V 200A circuits over to the ATS (L1 L2 N & G), and that neutral is landed on the MSP neutral bar and on the neutral bar in the ATS, do i need a 2nd neutral leaving the transfer switch and landing back on the same neutral bar it originated from in the MSP? It seems like I wouldn't if both sets were in the same conduit (feeder rules) and the subpanels neutrals are connected to the same neutral bar in the MSP, It seems redundandt to run a neutral there and back, the ATS is 2 pole generac and not switching the neutral. The subpanel would get it's neutral Via the neutral bar in the MSP still with just one neutral conductor landed between the MSP and ATS. Can someone explain this to me if I am wrong in my thinking on this? Is it wrong to think about this the same as a light switch not needing the neutral there, you can just leave it where the load is and switch the hots.? I know a light switch is not the same as feeders though. Doing it my way means 2 less 3/0 neutrals I need to find a home for in the MSP and less cost on unesecessary wire. This is not so difficult when the 2-200A MCB's are regulated to just feeding subfeeds separately in the MSP without landing on a distribution section becuase I can just unland all the wiring for both (L1 L2 N GR) and polaris tap the backfeed from the ATS directly onto those subfeeds which creates 2 open slots on the neutral bar for my neturals leaving the MSP to go feed the ATS. BUT, this is not always the case and usually one of the 2- 200A MCB's in these 400A MSP's load side land on a distribution section and does not have a neutral conductor I can remove to create a space to land in... Hope this question makes sense, it is difficult to explain. Advice would be much appreciated!!!
I have attached 2 different 400A MSP configs I am dealing with for reference.
