Looking for a WIFI switch that will work with two 110Vac hot/240VAC resistive anti ice roof heat, ie not neutral! Max amp is 20 but not concerned as I can place a relay in the system to turn on and off the high amperage.
I am closing this thread in accordance with forum rules. If you are not an electrician, we are not permitted to assist you in performing your own electrical installation or maintenance work.
