curt swartz
- San Jose, CA
- Electrical Contractor
I’m looking for advice regarding a proposed residential backup generator installation.
Years ago we installed quite a few generators for a GC that did work in the hills where storms would kill power for extended periods.
We would occasionally install generators in the flat lands but once you tell most homeowners that its not just buying/installing the generator, maintenance is also required like a car they decide its not worth it.
In recent year most choose to go with PV and battery backup.
Anyway………
Another GC we used to do a lot of work for but retired about 10 years ago is asking for a backup generator for his own home in the hills. The basic installation sounds relatively easy. He has a detached building that has a meter-main then an underground feeder to the main house. He wants the generator located at the detached building so we can just interrupt the feeder with the automatic transfer switch.
He wants the generator to start automatically but wants the ability to turn the generator off and back on from the main house. His thought is he doesn’t need power the entire time the grid is down. He only wants to occasionally run the generator to keep refrigerator/freezer cold and heat the house during cold days.
Back when we did more residential generators it was mostly Generac. We never installed any remote controls and I don’t remember that being an option.
For those here that do install generators is the manual control request reasonable/doable? If so any suggestion of manufactures and models of equipment I should be looking at?
Anyway………
