Volt-Amps
- Indianapolis
Chicago Electrical Code or NEC 2017:
Residential building with 8 tenants: Meter bank has (8) meters + (8) 100A breaker, each breaker and meter serve 1 of the 8 dwelling units. Do I need to provide one main service disc. for the entire building? If required, which code section references this requirements?
I'm not sure the 6 disconnect rule apply here because I've seen this done all over with no main provided for the building.
See image below:
See image below:
