jjhoward
- Northern NJ
- Owner TJ Electric
Mr. Inspector has flagged the use of the in house copper water lines to attach the grounding lugs for my two breaker panels (2 apartments with their panels in the same cellar space). Wants me to install a "grounding block" in one of the boxes to provide the necessary 3 lugs to terminate the external GECs, the water lines and the 2nd box. Is this code required?
Additionally, he has requested that a light be installed by the boxes, NEC code required?
Thank you.
Thank you.
