Their web page says "compliant with NEC . . . 410.16 (C)(5)" so that's correct.I believe the Halo SLD6 series is listed for closet storage space areas but not 100% sure.
Not totally correct. There are LED's that are made to be installed in the closet storage area. There is no distance for those to be away from anything. For instance, this is an led closet rod for your clothesAny light with a covered lense is usually sufficient.
There can be no exposed bulb.
If it’s an incandescent it has to be 12” away from the shelf.
If it’s led or fluorescent it can be 6” away from a shelf.
410.16(B)(5)Surface-mounted fluorescent or LED luminaires shall be
permitted to be installed within the closet storage space
where identified for this use.
I found this product at a hardware store. Pretty interesting. It just screws onto/into a keyless porcelain and converts it into a low profile LED fixture. Don't even have to remove the keyless porcelain.
I installed it in a closet when visiting a friend last fall that needed an upgrade in her closet, I didn't have any tools with me so this worked well for the situation.
View attachment 20470View attachment 20471
Costco was selling one recently just like that for like 11.99 color temp change and all. Not sure how much this one is.
