Rick Malone
- Sacramento, CA
- Electrical Engineer
2020 NEC 230.82 - Equipment Connected to the Supply Side of Service Disconnect regarding solar PV systems allows the following to be connected to the line side:
(6) Solar photovoltaic systems, fuel cell systems, wind electric systems, energy storage systems, or interconnected electric power production sources, if provided with a disconnecting means listed as suitable for use as service equipment, and overcurrent protection as specified in Part VII of Article 230
My question is would a critical loads panel connected to a Sol-Arc type inverter, enphase system controller 2, etc., connected to the line side of a service be allowed.
If generation is not underway, the critical loads panel would be an additional load to the main panel and main circuit breaker. I don't see a way to insure the meter / service conductors are not overloaded and/or protected. Also, an exact reading of 230.82 would seem to indicate you cannot have loads connected to the line side of the service.
Any thoughts?
Any thoughts?
