Residential Electrical Panels
m_herrera202 said:
How many spare breakers can I have inside a residential panel or load center.
That depends....
- how many spaces are there to begin with?
- how many spaces are you using?
Subtract the two, and that leaves you with the number of available spaces for spare breakers.
It is up to you - or the customer - to decide if you want blank spaces or spare breakers ..or a combination of spaces and spares.
:grin:
I must ask why you feel the need for spares in a resi panel? It's pretty common to load up a commercial panelboard, and even MDP's with spares. It's almost never done in resi, unless you accidentally knockout a panel cover knockout, then it's sometimes quicker or easier to just click a spare breaker in that slot.
I am not sure if you are asking what the maximum number of breakers one can have in a panel? 42 would be that answer but all residential panels seem to only have 40 circuits. At least for now in the 2005 code. Art 408.35
Quote: "A research team proceeded toward the apex of a natural geological protuberance, the purpose of their expedition being the procurement of a sample of fluid hydride of oxygen in a large vessel, the exact size of which was not specified.."
"Jack and Jill..."
"Jack and Jill..."
You are on a roll-- here try these out from my site-- you should have no trouble with them
http://members.aol.com/loveandlilies/NurseryRhymes.htm
bkludecke said:
My vote goes for the number and type of C/Bs shown on the panel label/listing info.
I agree. Always check what the panel label listing says. They make 20/40,30/40 and so on. I like to use a straight 40 circuit panel in residential work because of the space it give you. If I have a situation that a large 40 circuit panel looks bad then I would use a 30/40 which is much smaller.
Semper Fi. Buddy
number of breakers
number of breakers
I have heard that the '08 Code was going to lift the maxium number of circuits(42) in a panel. I have not yet purchased a new code book. Bring on the "piggy-backs"!!
The code rule won't change anything...until the listing for the panels is changed.
Don
What would the cost be for a piggy back 15 amps GFCI or arc fault? That would be tight on the wiring.
With a good portion of the breakers being arc fault and GFCI how bad would the heat get in the panel board? This is off the way I read the 2008 there will be more of them the normal breakers.
