Re: Residential Emergency Generator
Thanks for all of your responses! I will try to adress them all in this message. First off, I tried to sell the customer an automatic system with all loads that he wanted on to be routed to an emergency panel. I wanted to use a 15KW natural gas generator/auto transfer switch package with this emergency panel. but it was too costly for him. This person is an engineer on fluid flow metering and has a good mechanical mind that knows how to manage the loads. Doesnt do much for resale value of the home though does it! I should have posted exactly what I am doing in the post instead of adressing only the neutral problem.
This is what is going on here. The customer has a pretty large home. It has a 400 amp 120/240 volt single phase main service panel. The metering side of course is using ct's to meter the load and has a buss on the meter side. From this buss there are two feeds. One feed goes directly to a 100 amp main breaker on the customer side of the service panel and feeds a 100 amp subpanel located in the garage. The other feed also goes to a 200 amp breaker that protects distribution at the main service panel. This panel feeds the larger loads, AC, pool, etc and another 100 amp panel located in the house.
I am actually using 2 double throw 100 amp manual transfer switches that will tie each of the two subpanels into the emergency generator. Like I said, the customer is going to manage the loads at these subpanels. These subpanels only have single pole 15 and 20 amp breakers feeding plugs,lighting, furnace blower, circ pump, and such. The generator is overload protected.
I will be grounding the generator with a #8 wire from the generator frame to the grounding electrode system for the main service panel at the UFER ground.
Thyis turns out to be a $5000.00 job rather than a $15,000.00 job done this way. Even though the owner has the money, he wont do it the way I recommended! So I am doing it in this fashion, making sure it is 100% installed to the NEC is my focus now....
Thanks again...
Dan
