Kg808
- California
Ok..
i have a project that is a garage downstairs 2 bed 2 bath upstairs new construction in California.
Contractor just called and said that the fire flow switch needs to alert the bell as well as the smokies throughout the structure. I have not seen or been required to do this ever. I have done a quick glance into the code book. (2014) haven’t seen exactly which art would require this.
Every house weve we’ve done so far has been: 120v power to the flow switch then switch leg/neutral to the bell. Smokies interconnected to each other. But the two have always been separated. I hope that this may be a misunderstanding. Or it could very well be that I have been trained wrong and never been caught!?
AND if this is the case that the two need to work together, how does this happen? As the flow switch is just a switch. How does it signal the smokies? There must be a separate relay?
thank you as always for the knowledge!
