I need to install a 2Hp pump in a residential home for fire sprinkler system. I plan on serving it with a 240V single phase (motor is dual rated for 115V or 230V) circuit with a 25A/2pole breaker. I plan on installing a 30A rated fusible disconnect switch for service disconnect and overload protection (breaker used as short circuit protection).
Questions:
1. Can I run NM cable to the disconnect or should I use emt to disconnect? The motor is located in a non-finished area.
2. Does anyone know typically how the motor will be controlled?
3. If anyone has any good installation practices for this applicaiton I would appreciate your input.
Thank you.
Questions:
Thank you.
