What is the maximum distance that a floor receptacle can be placed from a railing ? In this case there is 11' of spindle and rail that run along one side of the room. The other side of the rail is basement steps leading down to a finished lower level. The problem that I run into with this particular floor plan is that there is a 42" wide hardwood floor that runs right next to the spindle/rail.One particular AHJ requires the recep be placed as close to the edge as possible thus puttingthe floor box with somewhat raised cover in the finished hardwood walkway. Can the recep be in the carpeted portion of the room which would be aapprox 44" from the stairway edge.Thanks.
