dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
The basement/ garage area of a common “A” frame home in my area has a steel beam running thru the center of the home at a 90 degree angle to floor joists. In the basement laundry part bored holes are common rules pretty straight forward.
But the typical garage has a finished ceiling and the nm cables are attached/ bundled between finished ceiling and steel beam exposed. Is this code compliant?
After the steel beam ends wires are bundled run along wall finished ceiling height to service panel drop about a foot then enter panel is this OK
334.15C gives some good info as does 300.4 but I’m having trouble. With the garages here having finished ceilings and the above methods seeming so common and probably incorrect is what causes me confusion
Thanks for your help
