Yes. I also meant to say "when locating a residential generator, not chimney. Sorry.
Quick question.. Would an access hatch on a chimney need to be considered as an "opening" when locating a residential chimney?
FWIW, the ash dump, being below the fireplace floor level and not fully sealed at that point, would be a potential CO entry point. If you turn on an exhaust fan inside the house, you could end up sucking fumes in through that opening. Is that a realistic hazard? I do not know, but I think it would come within the code limitations.I am referring to the ash dump. The "hatch" is going to be 5' away from the exhaust side of the generator.
If you seal the opening in the bottom of the fireplace the situation changes.
In our area the chimney ash dump door is considered an opening to the building. Manuf instructions simply says opening.
On occasion when there is no other alternative we have sealed off the door. this passes inspection.
It must be sealed at least semi perminante. if you need to get the door open you can with a little work. Never an issue How many times do you need to open that door. almost never.
