I’ve had a large number of leads and customers wanting portable generator hook ups. In the past I’ve always used a transfer switch in order to do that and installed the panel next to the existing one. However flipping the bill has been an issue and I’ve seen something different.
If you install an interlock kit on the main breaker and connect it to the 30A plug underneath of it. Is it against code to allow the consumer the ability to shed their own load so long as the interlock prevents back feeding the utility?
Any insight or code references would be great.
