solarsabin
New User
- Freehold, NJ
When building a residential generator platform (cynder block or Steel) for shore areas where the municipality requires (or customer) the lift of at least 4'. Does the working space for maintenance apply here? Can I build the platform within the footprint of the generator, or do I need to build it 30" wider to accommodate for working clearances. My only thought here is that as long as the maintenance area or breaker on the generator is not higher than 6'6", It's not needed. Thanks for any help here.
