Oakey
- New Jersey
Hi all...I see there is a lot of info on generators in here but I still am unclear on a few things. I am wiring a small 8,000 watt genny, it is going to feed a 100 amp auto transfer switch then to a small sub panel . It is not controlling the main house panel just a few emergency circuits in the sub. The transfer switch does not switch the neutral it is just a plain terminal bar.
My question is about the neutral configuration:
The generac genny and transfer switch both come with the neutral bonded from the factory, what would be the correct way of configuring them? I assume I need to remove the bonding jumper in the switch? Thanks
