This is probably a dumb question that I should know, it is whether I should use a jumper from the neutral bus to the ground bus in an old 100 amp. service? There is a ground rod with a #6 wire connecting it to the ground bar and its a 2 phase with bare neutral going to neutral bar. Do I use a jumper to connect them inside the service or leave them seperate? Me confused.
