The Great Sarducci
- Detroit, MI. USA
Today I ran into an unusual situation regarding a residential dwelling's interconnecting smoke alarm main power feeder circuit. The interconnecting smoke alarm circuit in itself is wired properly, however rather than having a dedicated branch circuit feeding power to the circuit, the homeowner has dedicated power for the smoke-alarms (and only for the smokes, as I was sure to verify) coming from a separate fused disconnect box, which is then fed from above-disconnect in the main service panel. In other words, the external disconnect box dedicated only to the smoke alarm circuit, is fed from above the main breaker in the main panel. This is the first time that I've ever seen it done this way, and my thought is that this was probably wired this way by some other sparky or DIY with the thought in mind that it would keep the smoke alarm circuit always switched ON even when the main breaker was switched off. It would make perfect sense if the smokes weren't already battery-backup. But since they are, I'm not quite sure what the point was of doing it this way? What I'd like to know is; is this setup even permitted? I tried surfing thru the code to find an answer, but not finding much (assuming as how most everything for smoke alarms is in the NFPA 72 code book; which incidentally I don't have a copy of). From a pure electrical standpoint, it would be safe; as it is properly protected. But coincidentally in my mind, I always understood that when a main CB is present in the service panel, that it must be able to disconnect EVERYTHING in the dwelling when opened. Now that I've witnessed this setup, I now need to be sure that I am not leaving something illegal in place as-is when the job gets wrapped up.
