stew
- federal way,washington
I need to pick the brains of some of you folks to see how you design and install kithchen circuits. It would seem that the 2 20 amp small applaiance required cicuits arent reallt enough to do all the jobs in the kitchen. If you home run to the reefer then it also must be gfi prtected I believe . That then would seem to me to require as single 15 amp circuit dedicated to the reefer soand locate d behind to eleiminate the possibilty of gfitripping and bringing the reefer down. Does running 2 20 amp small appliance circuits ,one 15 amp reefer circuit and one additional circuit of 15 or 20 to the diswasher/disposal/evrhot(maybe) make sense or am I overkilling this. Havent had a ton of resi setup experience so need your expert advise. Thanks
