Re: Residential Load Cals
I?m not a ?fellow electrician,? but I am a Washington State Electrical Administrator. I have two suggestions, but both would require that you remember enough of the question and the answers that given as choices. One is to write up the question and the choices, then write up your answer, and post it here. You will find many who are willing to offer comments and suggestions. The other is to send me a Private Message, and I?ll give you an email address. Perhaps I can be of some assistance off-line.
Here?s another thought: Have you seen any example questions in the back of the NEC, or in the Handbook, or somewhere else, that are like the ones you saw on the test? Were you able to work them out and get the right answers?
I suspect that Bryan has the key to your problem. I suspect that you are not taking advantage of an available demand factor.
