My question is dealing with single phase, 3 wire, load center feeders (208/120), and in the case I am interested in, it is for a high rise residential project serving condos.
I am confused as to how to size the neutral for a typical feeder. I understand there is a code section that allows you to reduce the neutral wire size (below the size of the phase conductors), but am not sure which code section that is.
But how can you be allowed to reduce the neutral wire size? Isn't the neutral load going to actually be bigger than the load on the phase conductors, due to the fact that there is not a third phase to cancel out the load on the neutral? If, for example, the load on phases A-N is 50amps @ 0 degrees, and the load on phases B-N is 50amps @120 degrees, the addition of these two vectors results in a load on the neutral greater than 50 amps ... I understand that this only applies for the 120V loads, and that a lot of load will be on the phase conductors only (ranges, etc.), but I still would think the above effect would occur on the neutral.
Any help on this topic would be much appreciated.
Thanks,
Thanks,
