I have a customer that has a nuisance GFCI tripping in the garage. This happens to be the refrigerator receptacle and connected to the load of the GFCI is the exterior light pole which is a 6' decorative fixture. I see nowhere in the NEC that calls for the light pole to be GFCI protected? I removed the wiring from the load and connected the pole to the line and everything is good but I can't stop thinking about the wiring running underground and connecting to the pole may be damages and possible future problems but I don't see the GFCI requirement as long as the proper depths are met?
