Background:
We installed an 1 1/2 PVC conduit leading from the basement of a residence to a detached garage. The purpose of the conduit is to feed a sub panel located in the garage. The conduit exists the residence at basement level, in other words, below grade level and underground to the garage.
Question: I need to seal around the outside of the conduit where it exits the wall of the home or , because of the below grade level penetration, water will enter into the basement.
What do you recommend I use to provide a seal around the conduit and brick exterior of this home?
Many thanks
Many thanks
