Re: Residential receptacle limits
This portion of the code seems to mislead a lot of electricians. If you read section 220.13, there is a method for calculation the load for other than dwelling units - however, in a dwelling unit, the code only requires you to balance the number of general purpose outlets with the number of general lighting circuits required. These general purpose outlets should not be confused with the required circuits (Kithcen, Bath, ect). Whoever put the garage on a bathroom GFCI either didn't know the code or was operating on an older version than 1996.
Hope this helps.
