Praedatus1
- Portland, Oregon
hey guys, I did a quick search and didn't find much, but I'm sure you've answered this already...
Our power companies here (Wyoming) are starting to make us pull in a ground wire with our 3 conductor URD for a house service, set a disconnect on the pole, and re-establish ground with a rod there. Problem is, the AHJ's are still making us bond our ufer and water #4's at the house and removing the bond bar at the house disconnect. Wouldn't that make a loooong ground fault travel...all the way out to the pole before a ground/neutral bond? Or am I messed up here? My boss says the house disco is treated like a separate structure sub panel now... ??
