residential service equipment (panel)
Sure, it's done all the time, usually with a main disconnect ahead of it.
Can you provide some more details on why you're asking this particular question?
Bullit said:
is it permissible to use main lug at your primary panel
You can use a main lug panel in certain instances. If there is no main breaker or main disco then you are limited to 6 breakers in that panel.
