eddie_kerri
- cincinnati, ohio
I need to relocate an interior 100 amp residential panel to an adjacent wall. The existing romex branch circuit cables are not long enough to extend to the new 200 amp panel I will be installing. I will be using the existing 100 amp loadcenter as a junction box and extending the necessary sized romex cables from the old panel to the new panel, making wire nut joints and splices in the 100 loadcenter . I have several options to do this: I can run conduit and wire accordingly or individual romex wires as needed. What I would like to do to save some money is run multiconductor tray cable from the new panel to the old. I work at a powerhouse and have access to tray cable. I have a nine conductor #12 cable tray cable. I want to use this to account for four 20 amp circuits . The tray cable is multi-colored, but I was just going to tape the neutral cables white on both ends indicating they are neutral conductors. Is cable tray cable permissible to use for this application? Do I have to use romex cable or run pipe and wire?
