residential service size conducters and condiut
dagwoodem57
New member
i have 1- 2 pole 30a for dryer,1-2 pole40a for ac,1-2pole 50a for oven,6-20a for lighting and recpts,what size service do i need and what size conducters and condiut for my service at my residence,i do not have a code book to refer to.
Re: residential service size conducters and condiut
The typical residential service of today usually requires a minimum of 200-amps. Really small homes and those with gas-powered aplliances may allow for a smaller service.
The code permits a minimum of a 100-amp service for a dwelling in any case.
The size of the conductors and conduit can vary depending on the situation. 2 inch conduit and 2/0 copper conductors are commonly used.
I would strongly suggest obtaining a current code book and ask yourself if you are positively sure you are qualified to handle a job of this scope. :)
You need to go to section 220 and caculate the required service size. You may not need a 200 amp
service. The breaker size is meaningless in this process. You need the actual load.
Dagwooden Seems to me from your profile listing an "electrician" you are asking a for assistnace to a basic knowledge. What type of electrical work do you do??
Do yourself a favor and call somone who is experienced.
