Residential Service
buddog57
Can anyone tell me what a price range might be for installing a 200 A service on a new construction residence in the Anchorage,Alaska area?
Also I would be interested in any information concerning a per opening price range for receptacles,switches,lighting outlets,ceiling fans,ect. as well as sub panel and feeders for residential new construction in the Anchorage/MatSu Valley area.
Thanks,
Bob.
[ February 12, 2005, 03:40 PM: Message edited by: buddog57 ]
Re: Residential Service
First, are you just installing a 200 amp service, or are you wiring the whole house with a 200 amp service on it.
Im not sure about Alaska, but in KY, I charge around $2.75 sqft for new constrution. Just to build a service alone I charge starting at $1500.00 for a 200 Amp Service. If there is a disconnect needed I charge an additional $400 dollars.
Im not sure about Alaska, but in KY, I charge around $2.75 sqft for new constrution. Just to build a service alone I charge starting at $1500.00 for for a 200 Amp Service. If there is a disconnect needed I charge an additional $400 dollars
I am not wiring the whole house,just installing a 200 A meter base with a integral 200 A circuit breaker,(which is what i am calling the service),and mounting it on the side of the house
with a under ground feed.Are we talking about the same thing?
Thank you for taking your time to reply and giving me information on what you charge.
Bob.
