Would someone tell me the required section(s) for wiring a residential tub in the bathroom with the air jets incorporated in them? It is a listed one piece unit and will need a 120 volt circuit. There will not be any water heater incorporated into it as it will use the warm tap water. I am a little confused as to the bonding requirements and wiring method such as having to use conduit or not. The inspector hasn?t been very clear on this aspect. I do realize it will need the typical disconnect. Thank you
