la_engineer
My friend has a single phase panel in house that uses a 3c14 cable (separate phases) on two 15A 1 pole branch circuit breakers using the white as a neutral for both circuits. One circuit serves a three way to the living room light and the other circuit serves a separate room. The problem is that the living room three way switch has 120V on one side (black) leaving the switch and the other side (red) leaving the switch has 60V (give or take a few volts). This condition exists even with the cables removed from the swith (all except the incoming).
Need help in determining where the 60V is coming from.
la-engineer
la-engineer
