residential wiring, panel box
wiseinspections
New member
I recently inspected a house panel box. It had a 10/3 conductor, The red was connected to a single 20 amp breaker, the black to a seperate 20 amp breaker. Is this acceptable, is no, why, code ref please
iwire
Massachusetts
Re: residential wiring, panel box
Can't answer the question with the provided info.
What are the breakers feeding and are the breakers on opposing phases.
midget
How do you know what phase a breaker is on? I don't udnerstand...
roger
Fl
Retired Electrician
Wait, wait, wait, just wait a doggone minute here. You are an inspector and you have no clue as to what you are looking at? ;)
Roger
rattus
Sounds like a 240/120 service in an older house or outbuilding. #10 is good for what? 30A?
And, strictly speaking, 240/120 would be 2-phase with the two hots 180 degrees (opposing)out of phase with each other. They must be 180 degrees apart in order to get 240V between them. Of course, we do not call it 2-phase lest we confuse it with real 2-phase in which the hots are 90 degrees apart.
[ December 03, 2004, 10:43 PM: Message edited by: rattus ]
roger
Fl
Retired Electrician
40 amps, but it may or may not be able to protected at that (maybe alot more even) depending on the load and what article would apply. This isn't necessarily the question here, there is more involved as in Multiwire branch circuits as mentioned by Iwire and Midget.
Roger
[ December 03, 2004, 10:47 PM: Message edited by: roger ]
roger
Fl
Retired Electrician
rattus, it would be a single 240v winding center grounded or tapped and the + - peaks would be 180 degrees out, the correct wording would be legs if we chose to use it.
Roger
clayton
roger,
thanks for explaining that as i always had a difficult time myself understanding if it was 240v between the legs why it was single phase
but now i get it ,(and its very simple)
thanks again
clay :D
jimwalker
TAMPA FLORIDA
Do home inspectors have at least the level of journeyman electricians ? We keep seeing post from them indicating they have no clue as to what they are looking at but charge for the service. :mad:
stars13bars2
You would think it possible to even charge more for wiseinspections as opposed to stupidinspections, or idiotinspections.
:D ;)
roger
Fl
Retired Electrician
You're welcome Clay.
Roger
jimwalker
TAMPA FLORIDA
"You would think it possible to even charge more for wiseinspections as opposed to stupidinspections, or idiotinspections."
I am sure he charges more.The question is what is the customer getting or should i say not getting
petersonra
Northern illinois
engineer
Most of them don't know a whole lot about roofing, heating, plumbing, or carpentry either.
You basic home inspector will be able to find really awful problems like termites, rot, lead pipes and 60 A services, but he may miss a lot of things that are not "right".
I still think the idea of having someone look over the house with a critical eye has value, even if they are not necessarily experts in all the trades associated with home building.
roger
Fl
Retired Electrician
Bob,
and I agree.
Roger
iwire
Massachusetts
Guys you ready for this, I am a 'NACHI Certified Home Inspector'
I have never performed a home inspection but I do have a nice certificate. :cool:
Yes the home inspectors make mistakes but they also find and cause to be fixed a lot of truly bad wiring that no electrician or inspector would ever see.
Also they bring this information to light at a time when people will spend the money to fix the problems.
The home inspectors I know do not think they are code inspectors and they do not want to do our jobs. As a matter of fact they make work for electricians.
Just my opinion, Bob
[ December 04, 2004, 06:21 PM: Message edited by: iwire ]
rattus
"Roger", Roger,
Yes, "legs" would be more appropriate, but as you know many of us get sloppy with our speech. And indeed 240/120 is really single phase derived from one phase of a 4-wire, 3-phase distribution system. At least that it what it appears to be from the ground, and this old man is not climbing any poles to check it out.
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
Originally posted by rattus: And, strictly speaking, 240/120 would be 2-phase with the two hots 180 degrees (opposing)out of phase with each other. . . . Of course, we do not call it 2-phase lest we confuse it with real 2-phase in which the hots are 90 degrees apart.
From the point of view of physics, this is a valid description. There really are two different phases, and they really are 180 degrees apart. It does not matter that they originate from the same single secondary winding. If you connect them to an oscilloscope, you will see two different signals, the one rising as the other is falling. But as rattus says, it is best not to call it by that name, for fear of confusion. We have chosen to give this configuration the name ?single phase 120/240 volt.? But that is a choice, not a mandate from Mother Nature.
ronaldrc
Tennessee
I have never understood how everyone on here gets 2 phase out of the Edison 240/120 single phase?
It is single phase only, two phase is 2 voltage source just like three phase is three voltage sources supplied by 3 lines for economical and functional reasons like the three phase motor.
There is nothing 180 degrees out.
Ronald :)
