ran into a calculation question on resistance. Question is as follows. A conductor of 117 feet in length and 980 sq. mils csa has a resistance of 1 ohm. What is the resistance of 1987 feet of wire of 9862 sq mils of csa? assuming i was supposed to use the first part of the question to figure out what kind of conductor im dealing with. I used the formula R= pL/a. I plugged in 12.9 for copper wire, converted sq mils(980) into circular mils (1248) and came up with 1.2 ohms . I did the same with the 1987 feet of wire with 9862 sq mils and came up with 2 ohms. Am i correct? any help is appreciated
