I am looking for a DP single throw switch that I can use as a disconnecting means for an electric unit heater.
The unit is 7500 watts 240V.
I am able to find a 40 amp rated switch but it only lists HP loads.
The switch has an indicating on/off and would work great for the way the wiring is set up in the finished wall.
Is there a conversion that would allow me to figure resistive load from a given HP rating?
I know that the motor starting will induce a much more greater load initially than a heater.
Thanks
Thanks
