Sam@CEgeeks
- Auburndale, FL, Polk County
Hello All, I am new to this so be nice!!
Here's my question, I understand that legally required and optional standby systems can have the same transfer switch, and even be fed from the same cabinet or switchboard section.. But since they are defined as different systems, do the respective branches eventually have to be separated at all?
Example, A single ATS feeds a distribution panel, that panel has main breakers for legally required and optional standby systems, once the panel branches are the legally required and optional standby systems required to remain separate? Can you mix in the branch circuit loads with one another after the separation occurs? The reason I ask is I am running into an issue in the field with this, and the engineer is telling me its perfectly fine.. Why separate the systems at all?
I cannot find anything to dispute this, but it seems like an uncommon practice, and do not think its a good one!
I hope to learn a lot from this forum, and some of your Great Minds!!!:happyno:
